Denso AC compressor adapters
Old 03-25-2013, 11:37 PM
zdiesel's Avatar
Default Denso AC compressor adapters
Does anyone know where I can source a set of AC adapters for a denso truck compressor? Nostalgic air parts lists them in their catalog but when I called them they said they were out of stock and demand was through the roof and practically laughed at me (so if someone from NAP sees this ).
http://www.nostalgicairparts.com/air...apters-592.php
It's the peanut style adapters that I need like those ^
Old 03-26-2013, 08:23 AM
Gray86hatch's Avatar
Vintage air might have them
Tim
Old 03-26-2013, 11:27 AM
zdiesel's Avatar
Looked there, no luck. They have some adapters but not for my compressor :-(
Old 03-26-2013, 11:32 AM
I got some from docs blocks couple years ago but they don't sell them anymore.
Tim
Old 03-28-2013, 11:17 PM
zdiesel's Avatar
Yeah, I called them. Apparently they only sell bulk order now, bummer.
Anybody else got any leads for me?
Old 03-29-2013, 01:01 AM
Restricted User
MonzterMtrSprt's Avatar
if you provide me with more details i could probably make em for you... is there really that kind of a demand? thanks
Old 03-29-2013, 02:07 AM
evldoer's Avatar
Try getting them off of a donar truck at a salvage yard. Then you can cut them and have ends welded on by someone with a tig welder. Im using the same compressor and I was able to get 1 end from doc blocks about a year ago, they only had 1 of them availabe at the time. If I was to do it over I would just scavenge them off a truck and modify to fit.
Old 03-29-2013, 06:03 AM
Did you ask docs who they sell them to.
Tim
Old 03-29-2013, 09:19 AM
zdiesel's Avatar
I didn't ask who they sell them to, not a bad idea.
Pulling and modifying blocks from a donor truck isn't a bad idea, I had thought of doing that. I'll keep it a consideration.
Yeah, when I called Nostalgic Air Parts they said if they had any in stock they would already be gone. Apparently a very popular part for them, I know a large number of S10 guys use the same compressor. There's one place that has both adapters but they want like $130 shipped for two of them (one is only like $20 and the other is like $95 apparently). What sort of details do you need?
Old 03-29-2013, 02:49 PM
oldtimelt1's Avatar
Don't know a lot about what your looking for, maybe this.
http://www.ebay.com/itm/Pontiac-G8-A...-/150926990305
Old 03-30-2013, 12:03 PM
zdiesel's Avatar
^not the peanut style fittings. Look in my first post to see the link for the style I'm looking for. I've already checked ebay, nothing on there.
Old 03-31-2013, 08:13 AM
Old Geezer's Avatar
A start????????
http://www.amazon.com/gp/offer-listi...6Q1ZC58R9KT06M
Old 03-31-2013, 10:47 PM
zdiesel's Avatar
Certainly could be a good start, I made a discovery though!!!!
http://www.apairinc.com/iView.asp?Ca...or%20Manifolds
PN 451-1105 and PN 451-1106 are for the denso 10S20F and 10S17F which is the compressor style I have shown below...
They also have the seals to seal them to the compressor and packs of o-rings that I need to replace. Going to be calling them tomorrow morning to see if they have them in stock and can sell them to me or know where I can order from. Will report back with my findings.
Old 04-01-2013, 01:41 AM
ls1nova71's Avatar
That looks like a good find, but I hate websites that don't list prices. I ended up having mine fabricated/welded from the original fittings like the other's suggested you do. In my case though, I don't think I could have got the adapter fitting and another fiting to fit in my space requirements since I really didn't want to notch my frame much.
Old 04-01-2013, 06:32 AM
ART T's Avatar
Will that compressor bolt to a 99 LS1,Fbody bracket?
Old 04-01-2013, 10:13 AM
zdiesel's Avatar
Sometimes you just gotta call! I agree it is much easier though if they have prices on their website and you can just order online. Art; Not sure if it will mount to an fbody bracket.
I called AP air, and it's a home run! Parts were pretty cheap too, $22 for one block and $16 for the other plus $4 for the two seals that go between the adapters and the compressor. part numbers!
451-1106 (Denso 10S20F/10S17F to #10 adapter block)
440-823 (Seal for ^ block)
451-1105 (Denso 10S20F/10S17F to #8 adapter block)
440-822 (Seal for ^ block)
They also have 10 pack's of AC o-rings for pretty cheap as well, $3 a pack. Good idea to go ahead and replace all the o-rings on your AC lines while you have the system apart, it's a high pressure system and in my trucks case the original ones were 11 years old. And o-rings are cheap, I went ahead and ordered a pack of #8,10 and 12 o-rings. I'll be sure to post pictures of everything when it all comes in and my final product.
Old 04-01-2013, 11:03 PM
ls1nova71's Avatar
No, won't fit.
Old 04-13-2013, 03:36 PM
zdiesel's Avatar
Parts showed up...like last week actually but I wasn't able to make it home from school last weekend. Everything looks good, ran me $58 shipped for everything, no verification on fitment yet as my truck is still getting the exhaust bent up for it...
AC parts...ran $58 shipped for everything.
Old 05-04-2013, 11:06 PM
zdiesel's Avatar
Finally got the parts on. Everything went on slick, just need to get it charged now.
Old 05-05-2013, 12:28 AM
01cherryreds10's Avatar
Money well spent that looks really nice
Quick Reply: Denso AC compressor adapters
