5.3 swap too much fuel pressure?
5.3 is out of 2006 tahoe. Swap was going great. Started and ran great. After running a few times it does not start as good but runs seems to be running little rich. If I clean plugs and blow out it starts and runs better for 10-15 minutes but then back to same problem of harder start and slight misfire. I am running 65-67psi which I think is a little high but wondering if that could be causing my running and starting problem?
I am running the s10 filter fpr (Wix) and not sure why my pressure is 65. Only thing I can think of is I plumbed it wrong at first (switched the supply and return port) and maybe damaged it...??? I will make sure my return line is not restricted though.
I would switch. I'm using the 33733 filter works great.
I have the vetter fpr/filter on order. I am conscerned that is not my only problem as even now with 61 psi if I run for about a minute it seems to flood pretty quick now. Maybe I need to unplug my battery to have computer re-learn fuel ratio though.
I wouldn't think you'd need too. Check your injectors. Pop the rail off with your injectors still in the rail and prime the system. See if a injectors stuck open. Also check your oil. See if it has an oil smell to it. I would bet you have fuel in the oil as well
I popped the rail off and primed the system and appears to have no leaks. Good call on oil. Could that be how I am running rich currently is from fuel in oil? I will change oil and see if that solves the problem.
