tci tcu question
Old 03-31-2013, 12:00 AM
billyflantos's Avatar
Default tci tcu question
I put a 4l60e in my carbed ls2 powered 69cst truck with a tci tcu to control it but it doesn't shift into the next gear until you floor it and it shifts from 1st to third when it does shift and then it wont shift into overdrive...anybody have any of those problems and what did you do to fix it??
Old 03-31-2013, 09:35 AM
kevin87turbot's Avatar
Is this the EZ-TCU? Does it show vehicle speed on the hand-held programmer? Does the TPS sweep from 0 to 100%?
Old 03-31-2013, 11:41 AM
yes...
Old 03-31-2013, 04:27 PM
Make sure it's not programmed for 4L80E mode. Is the transmission a known good trans?
Old 03-31-2013, 04:33 PM
One other thing, and I've only seen this a couple times, did the Setup Wizard ask you what the engine displacement is?
Old 03-31-2013, 09:52 PM
It didnt ask nothing but 8cyl. And the trans did fine before it was put in my old truck.
Old 03-31-2013, 10:40 PM
Check the resistance through both shift solenoids. You can just disconnect the harness from the TCU and check it there. If nothing is wrong there, call Ricky at TCI and ask him to test the TCU for you.
Old 04-01-2013, 06:32 PM
It has a tps error code that i cant clear...it has the correct settings from idle to wide open..i had to notch it to get the correct .05 at idle position and now i cant clear the tps error code out..ivd unhooked everything and let it for hrs with no luck also...
Old 04-01-2013, 08:41 PM
It has to be over 0.1V at an idle. Otherwise, it will set a code. If you have a multimeter, you can check wire B on the TPS and see what the voltage is.
Old 04-01-2013, 09:40 PM
fox12303's Avatar
Unless you made a typo above, you state your tps idle reading is .05 volts, this is likely the cause of your tps code. Haven't used my scanner in awhile but I believe a typical GM tps voltage at idle should be .4-.6 volts. If you don't have a scanner use your voltmeter as described above by kevin.
Old 04-10-2013, 12:01 AM
its still acting crazy..the tc lock up switch stays locked up sometimes when it comes to a stop now and the bump down indicator shows its has some input voltage and the 4th gear solenoid shows no ohms going or coming from it?? any help will be appreciated...thanks billy
Quick Reply: tci tcu question
