Need help. Fuel pump fuse 20a orange wire, where does it go?
Problem solved
I am rewiring my 1998 Camaro LS1 and I have everything wired up, but I can not find this wire. I know this wire has to be hot in order for it to prime or turn on.
Tracing this wire down, it is on the same circuit as PCM BAT fuse which is right next to it. They both have orange wires. The PCM BAT wire goes to the white/gray connector and I have that to a fused positive always, but I can't find this other orange wire. Where does it go after it leaves the fuse box?
