Fuel pressure issues
Hey gang, I completed my LS1 swap in my 64 Chevelle back in November and the car has been running great until this past weekend. First thing I noticed was that the car was not starting as quickly as it did before. I checked and replaced all the spark plugs and still had the same issue. I also noticed that I had lost a great deal or power so I picked up a fuel pressure gauge to test the sytem and found the problem, but not sure which to replace first.
With key on I have 0 psi. After several cycles of key on and off I can start to see the pressure raise just a bit.
With car at idle I have 30 psi which seems to hold under acceleration.
With key off the fuel pressure drops to 0 within a couple seconds.
I'm running an external walbro 255 pump with a corvette filter regulator.
I've heard that these pumps don't last long, but I didn't think it would fail in 5 months.
Do you think the pump is shot or the regulator? both parts where purchased new 5 months ago.
I'm running a fuel cell in the car so I can't really add an in tank fuel pump. What would you recommend I use?
Thanks for the help!
Do the return check as mentioned above but also do a voltage drop check to be sure you have a steady 12-13 volts at the pump. Low voltage would also give you low pressure. Check the pump ground too.
How's the pump wired? What gauge wire did you use? Should be at minimum 12-14 gauge wire. Anything smaller and you could have voltage issues, typically when it gets hot. So cold I would think your pressure would be normal with a steady drop but you say you have to cycle the key to get pressure. So I doubt it's the wiring but it's something to keep in mind.
I believe most electric pumps have check valves though my experience is they are not very effective. So pressure bleed down is not all that uncommon. I would continue to look for the cause of the low pressure and not focus on the drop after the key is off.
I thought Walbro made a decent pump. I'd go Holley or Aeromotive. Airtex and Delphi are quality OEM's as well as ACDelco.
I replaced the fuel pump and had the same issue so I picked up a regulator and it fixed the problem. FYI blocking the return line must not be a valid way to determine which unit is bad. After removing the regulator I compared mine to the new unit. On the new unit I can blow through the output and it comes out the input, but if you block the input the unit holds pressure. On my old regulator when I blocked the input and blew on the output it leaked out the bypass return line. This immediately told me the unit was bad.
