what is this sensor?
Can anyone help me with some information about what this sensor is? It is mounted to the front of the right head on an '05 GTO engine. It has a tube from one end that was hooked to the side of the throttle body and the tube on the other end went to something at the rear of the engine. It has a two prong electric connection on it and a schrader type valve on the tube on one end. Is this necessary for the operation of the engine or can I just remove it? This engine is going in a custom installation with a Porsche transmission.
Here is a photo of it.
http://s1103.photobucket.com/user/ch...ensor.jpg.html
LS1Tech Sponsor
If you do not have to have emissions testing then you can delete it and not run it. You will of course have to block unused ports and delete the trouble codes for the evap system.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
If you aren't running an emissions friendly swap, then you can remove it.
For reference/future identification, the green cap on the line going to it is a standardized thing for EVAP systems.
