Picking up a LY6 tomorrow should I take the computer and Harness
I have found a LY6 out of a 2008 sierra 3500 should I get the wiring harness and ECM I don't need any smog equipment I will be putting it in a 1963 Nova I plan on getting a LS3 intake and changing the cam will this ECM be able to be programed or should I look for a harness out of a F body car?
LS1Tech Sponsor
You would have to get the harness from a 2010 or newer camaro.
If you get the harness remember that you are stuck to the way it is routed. That harness and ecm will work for your application. You will need to extend the MAP connector.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
My advice ditch the VVT that means the harness and ECM. 200 for that ? ha
If you're putting in a Nova. All those wires is going to look very bad.
You can purchase a VVT - Delete kit for cheap. Find a LS3 intake for super cheap. Get a harness anywhere for less than 375.00 And ECM's are nickels meaning they are everywhere.
Do this and you could be pushing 500hp maybe 550hp with the right cam.
Just my advice..... I don't think you'd be happy with the look of a LY6 with all those wires... in the long run. Better to get it over with now.
