Need help fast!!!!
Old 04-18-2013, 09:04 AM
Hart_Rod's Avatar
Exclamation Need help fast!!!!
I removed the water jacket fitting (for the oil cooler) from the left side of my LS3 block in order to replace it with a brass plug. It was very difficult to get out and once I got it out I found out why. Either it was cross-threaded when it was installed or not enough sealent was put on it to prevent it from galling the threads. Either way, I can't install the brass plug. I've thought about trying to tap it, but it's a huge hole, 28mm x 1.25 threads (please check me on this). Any tips or suggestions? Thanks in advance.
Old 04-18-2013, 09:17 AM
Rick Speed's Avatar
I'd say tap and plug it. I've never seen a LS motor strip out like that though.
Old 04-18-2013, 01:18 PM
Hart_Rod's Avatar
Thanks. I think it happened because the fitting and the block are aluminum and they didn't put any anti-sieze on it. It only ruined the first 3 or 4 threads, but I'm not sure how the tap will start and I don't want to ruin the good threads.
Old 04-19-2013, 01:41 PM
Hart_Rod's Avatar
ttt...
Old 04-19-2013, 03:07 PM
LT1Altered's Avatar
Use a Dorman rubber freeze plug?
http://www.autopartswarehouse.com/sk...Fao7MgodHm0Alg
Quick Reply: Need help fast!!!!
