5.3 th350 notch mustang starter dragging
I'm working on a 92 notch mustang. The problem is the starter is dragging when the engine starts. It drags for a second or two. You have to feather the throttle to keep the engine from dying and its making it hard to tune the start up if the starter keeps this up. Anyway I've tried three different starters a solenoid. The car is still using the ford solenoid. I've also tried to shim the starter, even up to. 120. The car is running a flat 6.0 flexplate and spacer. The spacer is on the crank side.
Just lookin for someof input, maybe I missed something.
Any help is appreciated
My LTD wagon with a 5.3 did the same thing when I tried to use the starter solenoid mounted on the fender. I also tried different starters and shimming with no luck. I did away with the Ford solenoid and ran the start wire directly to the starter like a GM and it fixed it.
