has anyone done an ls1 in a dodge magnum wagon
Old 04-21-2013, 07:46 PM
all juiced up's Avatar
Default has anyone done an ls1 in a dodge magnum wagon
hemi's are to expensive im a wagon fan and want something that looks better then a caprice wagon
Old 04-21-2013, 08:09 PM
i r teh noobz's Avatar
Nope. I've seen a couple of Charger threads pop up but they didn't go anywhere.
Old 04-21-2013, 09:11 PM
chuckd71's Avatar
BMW wagon?
Old 04-21-2013, 10:48 PM
Rick Speed's Avatar
It would need all new gauges and everything because none of the electronics would work right
Old 04-22-2013, 11:25 AM
tfi racing's Avatar
Yep,not worth the effort,just buy a hemi wagon and save your money.
Old 04-22-2013, 01:42 PM
Verz's Avatar
But that's not hot rodding and its not like gauges are that expensive. Im sure one of the wiring companies can get things figure out, in fact I know there is one that was able to get a ly6 working in a Dakota using the factory gauges so its doable and not like a magnum cant be found cheap enough to make it worth it.
Old 04-22-2013, 01:51 PM
ASSuming On The Tree
audacious nick's Avatar
I'd get a better car. Like a bmw wagon. American is crappy
Old 04-22-2013, 03:23 PM
Jones'n's Avatar
That's funny, I have a friend with one in his shop right now wiring up an '08 Silverado engine and trans in to a Magnum. Will use the factory gauges as much as possible.
I'll see if I can get some pictures from him.
Old 04-22-2013, 04:21 PM
chuckd71's Avatar
OP didn't say he wants a hot rodding project, he wants a magnum hemi, but it was too expensive. The cost of a new motor and trans plus the work involved would probably bring a base model to or over the magnum price.
That said, having seen the interior of the magnum they gave my dad to drive for work I'd skip it altogether and get something nicer.
Old 04-22-2013, 06:57 PM
aknovaman's Avatar
First of all mopar is the most non-aftermarket friendly mfg out there. My buddy does glass installs, had to remove seats and door panel after a break in. Car would not start and had to be towed to a dealer and reprogrammed just to start the dumb thing. You cant put a cam in them cause there only a couple guys who can tune the factory PCM. Big heavy turds just like their 60's ancestors.
Old 04-22-2013, 09:09 PM
ZQV8's Avatar
Current performance wiring is doing the car jones'n spoke of.
Looks to be done from his Facebook page
Old 04-23-2013, 08:49 PM
Blackpony's Avatar
There are plenty of options for tuning, we tune them all the time at my shop. But yes the aftermarket for dodge in general is pretty limited and expensive.
Old 04-23-2013, 11:38 PM
gnx7's Avatar
There are only 2 good Chrysler products worth owning.... a Cummins truck or a Viper
Maybe the new Wrangler or Grand Cherokee that will have a turbo diesel option.
Old 04-24-2013, 08:07 AM
Noremac's Avatar
I call bs on aftermarket support. I own and daily drive a supercharged, and cammed srt magnum... Tuning is widely available, even on the new cars. They are heavy, but very comfortable IMO.
But i have been thinking.. If i did happen to blow the hemi up, i would rather spend the money and get an lsa or ls7 before getting another hemi for it.
Old 08-01-2013, 05:00 PM
s/clsxmagnum's Avatar
Default 2005 magnum lq4 comp cam supercharged
daily driver drive way build. supercharged, comp cam, 614 624@ 114, 4l80e, and 8 psi
Attached Thumbnails has anyone done an ls1 in a dodge magnum wagon-2013-08-01-17.11.42.jpg
Old 08-01-2013, 06:36 PM
Rick Speed's Avatar
Did you get the gauges to work or did you go aftermarket ?
Old 08-02-2013, 07:36 AM
So you got a shitty boat. Cool.
Old 08-02-2013, 08:35 AM
Default gauges
all gauges except speedo work. I haven't spent much time with that one, It uses abs for a signal. It worked before I deleted abs. I will go aftermarket. I will fit them in the stock cluster.
also for nick.... my shitty wagon goes 10.46 at 128 on a low budget build and weighs only 100 more pounds than my friends 2ss. and can seat 5! When you have kids this becomes important.
Old 08-02-2013, 08:50 AM
2GOOD4U's Avatar
WTF? Judging by your sig, you have no room to talk.
Old 08-02-2013, 08:52 AM
2GOOD4U's Avatar
Disagree. When I owned my SRT8, there were plenty of parts available for it. As far as the inability to put a cam & tune it - that's false too. There are tons of people running cammed hemi's w/ simple mail order tunes.
Quick Reply: has anyone done an ls1 in a dodge magnum wagon
