Blue Monte Carlo 5.3 Swap
Old 05-09-2013, 06:29 PM
BOXCHEV's Avatar
What the hell is going on in here?
You think you didn't tighten the head bolts down tight enough?...what?
I hope you didn't reuse the original head bolts. And I hope you used a torque wrench and not just a regular ratchet and socket to install the heads.
Old 05-09-2013, 07:50 PM
GreazyDaMonsta's Avatar
yes i used a torque wrench and new bolts.
Old 05-09-2013, 08:54 PM
the_merv's Avatar
Originally Posted by GreazyDaMonsta
anyone
You really need to find someone that can put eyes on it..as mentioned we can't help you here..
Well I cant, someone might be able to.
Old 11-19-2013, 11:01 PM
Default trans cable
does any body have pics of ls1 intake w/ 200r4/ th350 cable hook up on the throttle body? cant figure out how to hook it up.
Old 11-22-2013, 01:21 AM
ttt ok
Old 11-22-2013, 06:57 AM
tta656's Avatar
ttt ok
http://www.tvmadeez.com/ls1_cam/
this is what you need
going this route myself..
Old 11-24-2013, 03:23 PM
Is there a different route?
Old 08-14-2015, 09:15 PM
I know it's been 2yrs. But I finally got it running under its own power. Everything from before is finished. Now I have this issue with the blazer brakes.I'm trying to use the factory brake lines but every time I hit the brakes fluid leaks out the lines. Do I need the blazer hard lines and soft lines or what? How do I do a 8.8 explorer rear swap?
Old 08-29-2015, 12:42 AM
Default 1st drive
Bogs out in 2nd gear
Old 08-29-2015, 01:05 AM
'87 Monte SS's Avatar
Congrats on finally getting it rolling!
Old 08-29-2015, 01:06 AM
My brother wants to swap this too
I love my city #CHICAGO
Old 08-30-2015, 07:16 PM
  #32
Default Bogs out
I don't know why my bogs out in 2nd gear. It feels like it's losing fuel help
Old 09-01-2015, 08:13 AM
  #33
Default Help
Ttt help
Old 09-01-2015, 05:24 PM
  #34
N20zuki's Avatar
Do you have a CEL?
Old 09-01-2015, 08:14 PM
  #35
Originally Posted by N20zuki
Do you have a CEL?
What is a cel
Old 09-01-2015, 09:43 PM
  #36
lizeec's Avatar
Check Engine Light (CEL)
Old 09-01-2015, 11:50 PM
  #37
markpetersonii's Avatar
Default Blue Monte Carlo 5.3 Swap
Oh my. This thread is interesting to say the least. I guess one way of learning is submersion. Glad to see that you're trying.
Old 09-03-2015, 07:32 PM
  #38
Do you have a CEL?
I dont know if I have a CEL I didn't hook up. I guess I'll hook it up tomorrow.
And no I had no idea what I was doing but I learned thanks to you guys.
Old 09-05-2015, 04:33 PM
  #39
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
Old 09-06-2015, 08:44 PM
  #40
Default ok ok
What about the vss. Does it need to be hooked up? May that he the cause of my problem? If so, what is the pin #? I have blazer converted front brakes.
Quick Reply: Blue Monte Carlo 5.3 Swap
