Blue Monte Carlo 5.3 Swap
Old 04-25-2013, 06:38 PM
GreazyDaMonsta's Avatar
Talking Blue Monte Carlo 5.3 Swap
My dream of becoming part of a Elite Member of LSX owners.....
Old 04-25-2013, 07:43 PM
the start of it's future.
Attached Thumbnails Blue Monte Carlo 5.3 Swap-5.3-swap-2-.jpg   Blue Monte Carlo 5.3 Swap-5.3-swap-3-.jpg   Blue Monte Carlo 5.3 Swap-5.3-swap-4-.jpg
Old 04-25-2013, 07:49 PM
what is this?
Attached Thumbnails Blue Monte Carlo 5.3 Swap-1363402384384.jpg   Blue Monte Carlo 5.3 Swap-1363459165320.jpg   Blue Monte Carlo 5.3 Swap-1363402376487.jpg
Old 04-25-2013, 08:16 PM
Default stall and cam
i heard that you cant put a larger cam in your motor without putting a hi stall in your tranny
Old 04-26-2013, 02:29 PM
anyone
Old 04-26-2013, 03:03 PM
shanex25's Avatar
Magic tool.
https://ls1tech.com/forums/search.php
Old 04-28-2013, 12:03 AM
Red face blazer rear disc brakes
has anyone ever used blazer dics on their conversion:
Old 04-28-2013, 12:22 AM
tta656's Avatar
Yup do a search on www.turbobuick.com for the disc brake swap or google
Old 04-28-2013, 12:26 AM
chaman's Avatar
Do you know what youre doing?
Old 05-03-2013, 10:13 PM
Angry what is that sound when im starting the engine
there aren't any belts hooked up
Old 05-03-2013, 10:14 PM
Cool
nope not really but im learning.
Old 05-04-2013, 02:06 AM
69face's Avatar
dude!!!! glad you got it started, but you gotta be a bit more cautious. its your car and your life. both im sure hold a value to you. try not to lose either starting cars that way. on your cam question. yes there are many cam combinations that are out there that can be used without adding a converter. they are usually pretty mild cams and can give some gain, but the more the pay with these engines and swaps, the more your play. Enjoy carefully please!
Old 05-04-2013, 12:55 PM
Cool
Thanks. i will next time. i've been working on this for a long time i just wanted to hear it run. the sound that it made before it ran i thought it was metal to metal sound but as i thought about it. it became clear that it might be that i didn't tighten down the head bolts all the way. the sound that i think im hearing is air passing thur the gasket. like when you put your lips together real tight then blow. am i right anyone if not im in trouble
Old 05-04-2013, 01:47 PM
Stinger22009's Avatar
Good luck with your build man. You need to ask around the work place or something and find someone that knows more about motors than you for a go to guy.
Old 05-04-2013, 02:36 PM
the_merv's Avatar
Wtf happened in that video???
I'm scared..
Old 05-04-2013, 02:51 PM
LS1MCSS's Avatar
I'm scared..
That was one of those "hold my beer and watch this" stunts.
Old 05-04-2013, 02:54 PM
the_merv's Avatar
I'll say this the politest way I can..
No one here can help you, from what I can see already anything we type here will now help. You need help from someone that can give in-person hand-on technical assistance.
Worrying about Head Bolts and pumping what looks like gas in a water bottle straight into the Intake of an EFI Engine is NOT the level you need to be at when wanting to trust your life to a car you plan on driving after you build it on your own.
I would look around for some help. If you keep at this the way you are it looks to be a good candidate for a Darwin Award.
Old 05-04-2013, 06:06 PM
LS1MCSS's Avatar
I'll vote for him.
Old 05-07-2013, 03:59 PM
Talking No oil on pass side of the engine
OK OK OK. I GOT EVERYTHING SQUARED AWAY ON MOTOR I PULLED VALVE COVERS. ON THE DRIVER SIDE I GOT ROYAL PURPLE SHOOTING EVERYWHERE. BUT ON THE PASSENGER SIDE I GOT NOTHING IM USING A LH8 OIL PAN. WHAT IS GOING ON? WILL I HAVE TO PULL THE ENGINE FOR THE 3RD TIME?
Old 05-09-2013, 06:01 PM
anyone
Quick Reply: Blue Monte Carlo 5.3 Swap
