Finally starting my build 1966 lemans
So i picked up a 66 lemans about 5 years ago to do a frame off, when I took it down to the frame found the frame in bad shape so i put it on hold as I live in alaska and these cars can not be found up here. This summer was able to get a 66 tempest 4 door in good shape and also a 04 gto with damaged front pass side for a steel of $4500 complete car with 60,000 miles on it. I will be swapping the LS1 and T56 and interior into the 66 lemans. My question is there anything else worth using off the gto, should I use the radiator and elect fans, I will also be converting to disc brakes also. Another question is who can I send the pcm to have it flashed? I will be searching old forums on here also. Thanks for any help.
Check out this thread, he is using quite a bit if the donor GTO
https://ls1tech.com/forums/conversio...ac-lemans.html
