minimum exhaust manifold clearance?
Old 05-16-2013, 07:48 PM
steveinidaho's Avatar
Default minimum exhaust manifold clearance?
What is the minimum clearance for an exhaust manifold?
Just finishing up my ls swap, but i have a clearance issue with my hooker ls exhaust manifolds.
The clearance to my suspension upper A-arm is a about 1/8".
I already ground down the A-arm part that was hitting but it's still close.
I could grind the manifold but they are already ceramic coated...
Its probably what I'm going to have to do
I'm using Dirty Dingo "street rod" engine mounts with 1 poly and 2 rubber bushings(one under and one above).
I'm not sure how much movement the engine will have...
Old 05-16-2013, 09:34 PM
-TheBandit-'s Avatar
Well your alignment is going to affect the clearance. Do you know where you stand? If you have a lot of camber or caster, some of those rear shims may come out.
Old 05-17-2013, 01:01 AM
Yes, the alignment was ok, i had it done a few months before it was parked (before the swap started).
So i shouldn't need to move the spacing of the a-arm back further any time soon.
and if i have to I'll change the ball joint spacing instead of changing the shims behind the upper a-arm mount.
Old 05-17-2013, 01:05 AM
i r teh noobz's Avatar
Grind the flange.
Quick Reply: minimum exhaust manifold clearance?
