Cherokee box into A-body
I know this has been discussed several times but I would like to know if anyone can tell me what years of jeep cherokee steering boxes are used in GM A bodies, and if it is certain models like just Cherokee or Grand Cherokee or both. I am building a '71 Chevelle. Thanks
1992.5-1993 Alpha code AL or BT
1994 Alpha code AL, BT, or PD
1995 Alpha code JH
1996 Alpha code KD
1997-1998 Alpha code WK or BT
The alpha code can be found on the sticker on top of the box. If you get it from a yard be sure to get the mounting bolts with it.
Mine is from a 1995 Grand Cherokee, but I believe 1989GTA has the right year range. Three bolts and sawzall to cut the 2 lines and adjustment sleeve and I had it on the ground in less than 10 min.
Yeah, the 92-98 Grand Cherokee is the way to go. I'm pretty sure you have to get a rag joint from a 75 Nova. Interestingly, the box also fit in my 68 Bonneville.
