What to grab from donor car LT1 to LS1
Old 05-29-2013, 05:30 PM
93TAWicked1's Avatar
Default What to grab from donor car LT1 to LS1
My LT1 is toast so I'm going to pick up a 99 LS1 from a impound car locally here for less than fixing the LT1 would probably cost.
Just want to make sure I don't miss anything....
- Harness\pcm\pcm bucket
- Engine intake to pan
- Front suspension...I'm buying everything from brake to brake with steering rack on the k member.
- Exhaust manifolds and y pipe
Anything else I should grab I'm going to use the LT1 4L60E for now. Later I may go six speed.
Thanks!!!!
Bobby
Old 05-29-2013, 05:55 PM
bczee's Avatar
Everything you can !.. you can always use something or just sell it off and recover you money.
Nuts, bolts, brackets, tubing, pipes, BCM, Throttle Cable, Cruise Control. connectors, drive shaft, e-brake cable, fuel tank and sender/harness, etc..
If your trying to have it all work as stock in the LT1 car (what car is it ?). You might need other wire harnesses to support the interface between the LS1 and the LT1 body harnesses.
Just take it all ! LOL
Old 05-29-2013, 06:59 PM
Yeah I would but its coming from a salvage yard and I'm sure they will want money for all the little stuff. I could probably have him throw some stuff in but I'm not sure they will go for everything.
Its a 97 Formula. I'm a little concerned about the LT transmission now. I thought it would work fine behind an LS1 but from Mervs thread the electronics won't work?
Old 05-29-2013, 08:11 PM
BTW that Malibu is bueatiful!!! That was a crazy decision for me to go old pontiac motor in my bird with a 6 speed. I was thinking LS swap all the way but changed last minute.
Quick Reply: What to grab from donor car LT1 to LS1
