my turbo 5.3 notch build pics and video
89 coupe aje k member flaming river manual rack, lakewood 90/10 with eibac drag launch springs, rear is lakewood 50/50 drag launch springs upper and lower adjustable controll arms 373 with locker[prob go to 327 gear] through floor fram conectors. fuel system is a1000 pump -8 feed to boost ref reg -6 return 80lb inj. Ps1 harness, level 4 4l60 with yank 3200 stall.turbo kit includes turbonetics hurrican t4 78 with 96 ar 2 50mm turbosmart bovs and 40mm wg truck manifolds with v-bands 2 1/4 cross pipe and 3 down pipe to elec cut out custom y pipe to mack catback.motor is a 5.3 with 40k. it got the following ...
Katech Rod Bolts
gm swap pan
Pat G Spec'd Turbo Cam 222/226 .599"/.598" 116+4
Texas Speed 7.4' Pushrods
Stock 5.3 heads, Mildly touched up
Felpro MLS Gaskets
ARP Head Bolts
Comp 918 Springs
Edelbrock Victor Jr & Elbow
Need help with
1 drive shaft for the 4l60 i have the 60 yoke
2 upper and lower rad hoses for foxbody alum rad
3 throtal cable for car t -body with vic jr f body elbow
4 crossmember dont want to go with aje i want a transmission mount. Has any one used a foxbody crossmember if so what do i have to do to it to make it work and what transmission mount are you using
any thing you can think of i left out
Thanks for your help will post pics this week
https://www.facebook.com/photo.php?v=10200614099703657
Katech Rod Bolts
gm swap pan
Felpro MLS Gaskets
ARP Head Bolts
Comp 918 Springs
Need help with
Last edited by s10pro; 08-19-2013 at 07:58 AM. Reason: update with info and picsand video of my build
Driveshaft will have to be measured and built by your local driveshaft shop or maybe a sponsor.hoses im not sure on since I used a fbody radiator.for the throttle cable I used a 5.0 efi cable attached to the cruise control arm,but I did have to shorten it to get the right throw.
I used aje kmember and aje crossmember with 4l60e trans and used a stock foxbody driveshaft and a TH350 yoke on the front with a conversion u-joint from napa sorry don't have the part #
