Need Help in Memphis...ASAP...
Old 06-08-2013, 10:05 AM
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Default Need Help in Memphis...ASAP...
I have an emergency in Memphis.
I am scheduled to take a road trip to Texas this afternoon. While inspecting my car before the trip, I discovered that my fuel rail is leaking.
Does anyone in the Memphis area have a LS3 fuel rail that I can use? I will pay what you want and will replace it as soon as I can get one from the dealer.
Please! If anyone has one on an unused crate engine, or anything laying around, please contact me asap.
Thanks..
Andrew
708-two zero seven 63 two three
Old 06-08-2013, 10:06 AM
sopes's Avatar
or just throw it out there for ya, get some JB qwik weld and try it, I beleieve they even make a fuel line repair kit just so you can get on the road
Old 06-08-2013, 10:18 AM
KY Nova's Avatar
Can you post a pic? Someone may have a fix if they could see it. Just a thought.
Old 06-08-2013, 10:35 AM
Thanks guys. I am going to pull the rail off, and found a welder in town that might be able to fix it. Basically the nipple that holds the shrader valve is busted off...
Andrew
Old 06-08-2013, 12:00 PM
bczee's Avatar
Is it the rail or the valve ? Have you tried to replace the valve ?
Worst case, break it off and weld it shut.. or screw some kind of cap over the end. Make sure you flush the rail clean first (no carb cleaner !) Be for welding. Maybe braze the crack close.
Not a good way to start a road trip! Good Luck.
Old 06-08-2013, 12:17 PM
The plan right now is to remove the nipple and weld a plug on the end of the rail. Unfortunately, the welder is not available until 3:00pm, so I have to sit tight.
Important safety tips kids: Don't hang the sender for the fuel pressure gauge off that nipple.
The right way to do it is to run a short off that fitting and mount the sender to the firewall, or other secure spot.
I am just glad this didn't happen in the middle of nowhere, on the side of the road, and set the whole car on fire...That would suck.
Andrew
Old 06-08-2013, 12:23 PM
bczee's Avatar
yeah, Nowhere is not good for finding parts and help ! LOL..
Hope you're back on the road to Texas soon..
BC
Old 06-08-2013, 12:25 PM
67Skylark's Avatar
wish I was closer I could lend you the one off my car, got to be a dealer/hotrod shop/junk yard up there has has one. Good Luck hope you make it.
Old 06-08-2013, 12:30 PM
I shot a quick video to show what's going on...
Andrew
Old 06-08-2013, 10:59 PM
bczee's Avatar
You should be able to Braze it.. if the rail is SS, you will have to use a Silver brazing rod. If not normal Brass/Bronze will do.
BC
Quick Reply: Need Help in Memphis...ASAP...
