2001 ecu, 2000 fbody flash and harness, which O2 sensors?
I was just curious which front O2 sensors I needed to purchase with the above combination of parts. I thought I read somewhere (can't find the thread now) that there were two different O2 sensors that fit the same plug but one will work, the other will not. I would like the ability to run in closed loop, but wondered which part number to get. Thanks guys.
LS1Tech Sponsor
All of the Fbody cars used the same oxygen sensor from 1998-2002.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
But are these compatible with a 2001 Tahoe ecu? I just remember reading somewhere about a grounding issue and 2 different o2 sensors or something. Sorry I can not be more specific. I just remember one was effectively grounded by the case the other required an external ground wire but both would plug into the same pigtail.
