drive shaft yoke t56
Old 06-23-2013, 07:44 PM
jlew0006's Avatar
Default drive shaft yoke t56
Hey guys doing a ls1 t56 swap in a 2000 mustang. Just curious how far my driveshaft yoke needs to go into my t56 trans. Is 2.5 inches enough? And also if anyone knows how deep a yoke can go. I found an aftermarket yoke that would go 5.5 inches into the trans. Is that to deep and would it bottom out?
Thanks! Jason
Or of anyone has a stock yoke that they could measure for me. Barrel length and end of barrel to center of u joint would be awesome! Thanks
Old 06-24-2013, 09:29 PM
Lotus289's Avatar
I have an OEM Aluminum Driveshaft sitting in my garage. I can take some measurements tomorrow night and post them if no one has by then.
Old 06-24-2013, 10:15 PM
jlew0006's Avatar
That would be great! I appreciate it
Old 06-25-2013, 08:08 PM
Lotus289's Avatar
The first pic is from the base of the balancer to the end of the input shaft. The second pic is from the centerline of the U-Joint to the end of the input shaft. I don't know how much room there is for an input shaft on a T-56 or if 2-1/2" will be enough, but maybe these will help you out a bit.
Old 06-25-2013, 08:37 PM
jlew0006's Avatar
Thank you very much. That's the problem I'm having. I have found two yokes that I can order. One is 3 5/8 barrel which leaves only about 2 1/2 inches in the trans. Other is a 6 inch barrel and that will put 5 inches in the trans. I would go with the larger if I knew 5 inches would fit but i don't know if it will bottom out.
Old 06-25-2013, 11:30 PM
markbsae's Avatar
If you have a solid axle you want about 3/4" to 1" more slip at ride height. With suspension droop it will disengage more. The short yoke is probably for cars with a fixed diff that doesn't travel up and down with rear suspension travel. With a live axle like a mustang would have you want the long one.
Quick Reply: drive shaft yoke t56
