mechanical temperature gauge ???
I ended up tapping the flat part of the water pump and running it there. I was going to use the access port on the passenger side head but decided against it because the probe style temp gauge stuck out past the head once you used a brass fitting that was converted to metric thread and I didnt want to risk tapping out the head. I don't have any problems with the top of the water pump
Street and Performance Mena Ar. www.hotrodlane.cc Page 92 of the online catalog.
12mm X 1/8, 1/4, 3/8, or 1/2 NTP Coolant Sensor Adapter.
They are a phone up and order, or walk in type place. Website sucks. 479-394-5711. Guy name Mark runs/owns the place and really knows LS swaps. Can help with just about any question you may have or any custom parts.
adaptor, coolant, electrical, gauge, gauges, ls, ls1tech, lsx, mechanical, performance, street, swap, temp, temperature, water
