Alternator Connector / Terminal ID Help
Old 07-11-2013, 09:26 AM
-TheBandit-'s Avatar
Default Alternator Connector / Terminal ID Help
Can anyone tell me what kind of terminal and connector this is? This is for a DR44 alternator for my '07 LY6. It does not appear to be Metripack. I would like to get some new terminals so I can make new/extended wire lengths.
Thanks for any help!
Attached Thumbnails Alternator Connector / Terminal ID Help-alternatorconnector2-custom-.jpg   Alternator Connector / Terminal ID Help-alternatorconnector-custom-.jpg
Old 07-11-2013, 12:34 PM
LS1Tech Sponsor
BP Automotive's Avatar
They are Bosch terminals.
For that connector we use the delphi version, I wish we could help you with the terminals, but I do not know of anyone that stocks the terminals.
If you would like a pigtail with a specific length of wire let us know! Cost for the standard pigtail that you need is $13.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 07-11-2013, 01:01 PM
Are you saying you use a Delphi metripack connector body and terminals that is compatible with the same mating connector on the alternator that currently interfaces with the Bosch terminal?
Thanks for the help!
Old 07-11-2013, 01:21 PM
wildcamaro's Avatar
Mouser.com carries pretty much any terminal used in weather pack connectors that you can think of...I've used there terminals with great success to build obd2 ports in swap vehicles
Old 07-11-2013, 01:59 PM
LS1Tech Sponsor
No, I use a Delphi Equivalent connector for the alternator sir!
__________________
1-888-467-4491
Old 07-11-2013, 03:22 PM
So Delphi makes a Bosch-style connector? I am confused.
Old 07-11-2013, 06:01 PM
LS1Tech Sponsor
The connector is different, however the specs are the same. Ill get a picture up of the connector after bit.
__________________
1-888-467-4491
Quick Reply: Alternator Connector / Terminal ID Help
