08 5.3 into 75 camaro
Old 09-15-2013, 09:20 PM
  #61
rickybobbyss's Avatar
I think those are 1.89 intake valve heads.can u swap all you parts onto those,,ya headers can get very pricey!
Old 09-15-2013, 09:41 PM
  #62
M6 Swap's Avatar
^the 862 heads or 241s? From what everybody's telling me I'm not gaining anything with the 241s so ill prolly just pick up the bare 862s and swap over my valves etc
Old 09-16-2013, 06:54 PM
  #63
omc8's Avatar
M6 did you see my 3 posts from yesterday ?
Old 09-16-2013, 06:58 PM
  #64
M6 Swap's Avatar
Yes sr I did. Thanks for the feedback , I'm actually picking up a set of 862 heads tommorow.
Old 09-16-2013, 07:15 PM
  #65
omc8's Avatar
You all ready have a set on your 5.3 , why were you considering LS1 heads , thinking of going turbo down the road ?
Old 09-16-2013, 08:14 PM
  #66
M6 Swap's Avatar
well funny story, i bought some degreaser and cleaner from home depot and set one of the heads in it to "soak" over night. just wanted to clean off the carbon and dirt, when i pulled it out of the degreaser the next morning there was about 1/16" eaten off of the head all the way around where the degreaser was! i took it to a machine shop and they said that it was trash! so now i have to pick up another set, just my luck. but i did come across a good deal with a local guy. im picking them up tommorow.
Old 09-16-2013, 08:15 PM
  #67
M6 Swap's Avatar
and no plans for turbo, putting in a cam and leaving it stock other than that.
Old 09-16-2013, 08:16 PM
  #68
M6 Swap's Avatar
if i pick up a LS1 car intake will my truck fuel rails and injectors fit? i searched it and found mixed answers. thanks for all the feedback guys
Old 09-16-2013, 08:52 PM
  #69
omc8's Avatar
What degreaser did you use, it wasnt purple power was it ? The great thing about these 5.3 heads there are plenty around and they are cheap. Are you going to put bigger valves in them ?
Old 09-16-2013, 08:56 PM
  #70
M6 Swap's Avatar
it was the home depot knock off of purple power. and no plans for bigger valves. i was looking around the internet for oil pan options and i found auto zone has a f body oil pan for 59.99? it says its metal and doesn't have the oil level sensor hole, they also have the oil pickup tube for 69.99, if i went this route only other things i would need is windage tray and oil tube and dipstick, has anybody used their pan? seems to good to be true?59.99
Old 09-16-2013, 09:13 PM
  #71
omc8's Avatar
I don't know about AZ F body pan . But you can find complete used ones for $200 if look in classified ads. When you start adding all the acessories it starts to add up real quick.
Old 09-16-2013, 09:29 PM
  #72
M6 Swap's Avatar
why wont the truck windage tray work with the f body pan?
Old 09-17-2013, 04:50 PM
  #73
M6 Swap's Avatar
just want to say thank you to jdoyle for the truck heads, picked em up today and dropped em off at the machine shop. waiting on my Lunati cam and valve springs to show up now. making progress! hopefully i'll have the car back at my house this week so i can start prepping the firewall for smoothing and paint!
Old 09-17-2013, 07:07 PM
  #74
omc8's Avatar
IIRC I believe they will but check the part # to be sure . Have you considered this oil pan.
http://www.jegs.com/i/GM-Performance...12593/10002/-1
Old 09-17-2013, 07:21 PM
  #75
M6 Swap's Avatar
Wow! Had not seen that, that's by far the cheapest pan kit I've seen. Has anyone tried it on a 2nd gen camaro? It says it will fit 55-95 gm veh but just wondering.
Old 09-17-2013, 07:23 PM
  #76
M6 Swap's Avatar
Also want to give a big thank you to Steve at Lunati for helping me out with a cam and valve springs! I would recommend him to anyone looking for a cam and some very good advice.
Old 09-17-2013, 07:38 PM
  #77
M6 Swap's Avatar
Just searched muscle car pan on nasty z and all say it hangs to low . My car is lowered so I think I have no choice but to go with f body pan. Although I have seen some people cut the truck pan and pick up tube.
Old 09-17-2013, 08:54 PM
  #78
Gooker928's Avatar
Originally Posted by BLK02WS6
Like I said over on the Nasty - I think you have a 2003 5.3L because it is the only one that came with a 1MB PCM (you have blue and green connectors) and a cable drive throttle body...
I agree.
You have the same setup I have.
Mines a 03.
Old 09-17-2013, 09:01 PM
  #79
Gooker928's Avatar
well the Camaro that I swapped my motor into is gone! now its time to start working on mine again, first thing on the agenda is to tear down the 5.3 and clean it up, paint the block and valve covers, also want to put a car intake on it cause they look 100 times better! after thinking about it I don't think im going to swap a cam or heads, im going stock other than headers and tune.
You HAVE to use a car intake.
The truck intake sits to high.
Old 09-17-2013, 09:04 PM
  #80
Gooker928's Avatar
do I need to port my oil pump?
I would recommend using a camaro oil pan.
It fits like it was made for the 2nd gen camaro.
Quick Reply: 08 5.3 into 75 camaro
