s10 blazer with brp longtubes what oil dipstick
the oil dipstick that came with my h3 pan doesnt work with my brp longtubes so i am wondering if anyone knows of another dipstick that will work
You aint holdin your mouth right, lol. It wiggles right in. slide the dipstick in the block with the yellow part away from the motor, then turn it towards the bolt hole, should line right up. If you tried the other way, it may be bent, I did the same thing, second one I did that way and I went right in. You may have to grind a bigger flat spot on the edge, its pretty close to mine
It should work. You may have you leave it slightly out of the block too. Then when you turn it shove it down. I had a trans line leak and had to take the headers and dipstick off 3 times, so I got good at it, lol
