Swapping in F-body gauges in my swap, problems.
I put a 5.3 and 4l60e in my 68 c-10 and had a 01 z28 cluster, so installed it. Oil pressure, volt meter and check engine light work, nothing else. It seems like everything that runs off the serial data connection isn't working. I know that wire is hooked up correctly because I split it to run my obd-2 and can pull all the info with hptuners. Anyone had any run ins with gauges not working? Surely it isn't something between the truck and car gauge setup would it be?
