Harness question - finally finishing my LS6 into 280Z project
OK, I'll keep this one simple and hope that I don't get beat on for asking the question, as I know there are so many threads on harnesses.
I have a '78 Datsun 280Z that has an LS6/4L60E from a 2002 Camaro that I want to do the simple mods to make the factory harness a standalone setup, AND I have the 2002 Corvette Z06 gauge cluster that is being installed into the custom dash.
First, is there a link to a thread or to a site that simply lists the parts & mods needed to get the car running in regards to wiring. I am running A/C and the Camaro dual fan setup, so I need to retain that wiring, as well.
Second, I assume there is a plug in the harness that runs to the gauge cluster? Besides the fuel level, isn't all of that run through the ECM? I have to do work to get the fuel gauge working correctly, but that is a minor issue once I get everything else working.
I got the car back from paint shop and nobody has worked on the car but myself, so I have no problem doing the work, just need a little guidance & understanding on this setup to get it going.
I appreciate the help.
Lt1swap.com has all the wiring information you should need to get it running. Its pretty simple once you get started.
I think the gauge cluster requires a BCM to function.
Looks great. Are you the same Savage42 that sells R200 clutches on HybridZ?
LS1Tech Sponsor
There are tons of wiring diagrams everywhere. We offer diy kits too, some you have to wire in, and some are plug and play depending on what harness you have. We dont have them up on the website just yet, but you can check them out in our ebay store link in our signature. The Wire in kits come with instructions to help guide you through the installation.
Bill
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
Agreed.
The harness is always what gets skimped on. Ive seen it 1,000 times. Even on VERY high dollar builds.
__________________
1-888-467-4491
1-888-467-4491
I appreciate the input and suggestions. I will take my time and get it figured out. The engine & harness have only 28k miles on them, so it's in great shape.
Either way, at least I will educate myself on how all the electrical is setup in the car.
I have pics and will definitely be adding and taking more as I finish the car very soon. I will most likely update my Cardomain page or put it on the Hybridz forum. Will have plenty to add in the coming weeks & months.
Just got my 6.6 pound Braille lithium battery (which didn't exist when I started this project years ago) where I originally planned to use an Optima. Oh well, I'll just make a cover for the sunken battery box area on the passenger side corner at the firewall since the battery is less than half the size, too.
