Need some advice to build an ls1
I'm new, don't know as much about engines but I want to learn, I have a 82 el camino and I'm looking on putting a 5.3 ls but I want to build it as an ls1 I want atleast 350 horsepower or more I would appreciate for ur help
You can almost get 350 HP out of a 5.3 without changing anything. Just a cam upgrade can get you to 400 hp at the crank.
Some guys will bore out a 5.3 to the size of an LS1 5.7. The crank in the 5.3 vs. 5.7 is the same except the 5.7 is lightened and balanced for heavier pistons.
Good luck
Bret
Good luck
Bret
