S14 kouki ls1 Starting Problems
I have a ls1 off a 2002 camaro ss and the car wont start unless i floor the gas pedal and attempt to turn it on sometimes it wont even start that way because i end up killing the battery, but the car always starts in the first try if i disconnect the tps sensor. If you have any input on this problem please let me know. I have replaced the iac and tps sensor.
^^Not saying its the issue but I would triple check it. Many people on the Nissan Forums have had issues with ChaseBay harnesses in the past. Some have had to send it back to them 3-4 times to get all of the issues worked out.
^---- That's true. Wiring Specialties seems to be the go-to people for this in s13 and s14 chassis now days.
I agree... check the tps signal and make sure the sensor is good. If you're still using the stock ECU, I've heard you may need to perform the TPS re-learn procedure. Good luck!
