ls1 fbody alternator in carb application, can it work
Old 09-10-2013, 07:59 PM
zamora7's Avatar
Default ls1 fbody alternator in carb application, can it work
Simple question, can it be done? I have the pigtail for it, but I don't know how to wire it out if it's even possible, or does it need the pcm to run it? I also have an older alternator but no bracket or ways to make one.
Old 09-10-2013, 08:03 PM
LS1Tech Sponsor
BP Automotive's Avatar
You can solder a resistor inline to make it work.
We also sell the pigtail with the resistor already soldered in and several feet of wire for routing it through your vehicle. The price for that is $15 if you so choose to go that route.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 09-10-2013, 08:09 PM
zamora7's Avatar
Can you give me a little more details? As in where it has to be wired to. Wiring kicks my *** lol.
Thanks for the quick reply
Old 09-10-2013, 08:55 PM
LS1Tech Sponsor
I added a pic of what we have.
If you search the forum there is a diagram somewhere in this forum, I dont recommend the tape on the wire in the diagram picture though.
__________________
1-888-467-4491
Old 09-10-2013, 09:05 PM
zamora7's Avatar
Cool, might be dumb question, so what exactly does the resistor do?
Old 09-10-2013, 09:43 PM
1981TA's Avatar
The resistor keeps your car's harness from delivering too much voltage to the alternator's regulator, which would in turn "instruct" the alternator to generate too much voltage to the car. The end result of this is that the alternator usually burns up in a short time. It also can cook your battery.
Old 09-11-2013, 10:53 AM
zamora7's Avatar
Thanks for the info
Old 09-11-2013, 07:09 PM
Pop N Wood's Avatar
If you hook it to the charge light in your dash you can delete the resistor. has to be a bulb type light and not an LED. That way you get to keep the idiot light.
Old 09-14-2013, 11:24 AM
82 ls1 cutlass's Avatar
What size resistor is it?
Old 09-14-2013, 01:00 PM
1981TA's Avatar
470 ohm.
Old 09-14-2013, 03:03 PM
dogsballs's Avatar
i just did this in my ls drag car. my alt had 2 wires in plug, white which loops back to the main terminal with big feed to battery/starter; and brown which goes to the dash with small globe (similar to autometer light) which is fed power on ignition.
i run an engine plate but i utilise the two top holes for normal alt bracket, but made my own spacers and link bar, then actually use two sail shade stainless adjustors. bought a 790mm 4 rib pulley from local parts store.
Old 11-20-2013, 06:37 AM
jays78's Avatar
I am in the middle of installing a ls1 from a 2002 f body into a 78 corvette, I need one of those resistor pigtails you have.
Is it possible to use my factory alternator gauge?
Forgot to mention, It has a carb conversion.
Old 11-20-2013, 01:30 PM
Pop N Wood's Avatar
If your factory gauge has a charge light you can use that in place of the resistor. Just run the wire straight to the bulb in the idiot light. The bulb takes the place of the resistor. The other side of the bulb needs to hook to switched 12V.
Quick Reply: ls1 fbody alternator in carb application, can it work
