oil pressure and water temp
Old 10-11-2013, 09:55 AM
6secNaLs1's Avatar
Default oil pressure and water temp
I have a 97 camaro v6 car with a ls2 wirh a carb. Does anyone know how I can keep factory cluster and make the water temp and oil pressure read. I also have a 98 z28 cluster
thanks
Old 10-12-2013, 01:42 AM
the_merv's Avatar
Get a 1996 Cluster...use the LS1 Oil Press Sensor and wire it into the Harness, and use the 1998 Sensor part number 12551708, Pin C on the Connector will be to the Gauges. It's the same as the TPS Connector.
Quick Reply: oil pressure and water temp
