98 s10 ly6 swap which accecories should I run / what transmission
Doing a ly6 swap into a s10 what front accecories should I use to have enough space an is there a way to delete the AC ??
An the that dod n vvt will be deleted going with a tsp ms3 ls3 intake n TB an longtube headers
Also wondering whats tranns to use its between a performance 4l60e or a 4l80e
Can the 4l60e handle the boltons I mentioned I wont do much after those.
You can use the truck front drive stuff and still run fans with the factory radiator.
As for the transmission the 80e is hands down stronger however if you have someone build the 60e that is capable and knows what the hell they are doing you can make one live.
You mean use the s10 stock radiator an fans ?? DWould good enought to cool down the 6.0
An im thinkin about going with a stage 2 4l60e im not going for big power so it should be more then good
Oh an does someone have a diagram of how the belt will go with no A/C
Are you running A/C ???
I also did a lot of overkill stuff because I'm OCD as hell and don't like cheap ****. Like the exhaust I had over 2,000 in lol
All lines are S-10 except for the compressor lines that I robbed off a full size truck and had the ends made to mate to the s-10 condensor and accumulator.
Ima do 1 7/8 long tubes no cats x pipe true duals through some straight through mufflers
