4th Gen seats in a 1st Gen Camaro
Old 10-16-2013, 04:37 PM
rockportag03's Avatar
Default 4th Gen seats in a 1st Gen Camaro
I've found a few threads where this has been done (installing 4th gen camaro seats into a 1st gen camaro).
Some cut/weld the 4th gen seat tracks and modify them to fit the 1st gen floor while others fabricate brackets that allow the 4th gen seats to simply bolt in. My question is, is there any person or company that is mass producing adapter brackets that allow for this adaptation?
Thanks.
Old 11-13-2013, 06:24 AM
bigarmzz's Avatar
im curious about this as well
Old 12-11-2013, 11:49 AM
To the top.
Hoping for a response.
Old 12-11-2013, 05:24 PM
reedld's Avatar
I've never came across any brackets for this.....I adapted my 2nd gen brackets to match up with the 4th gen seats. I used aluminum plate scraps...drilled holes..done. It's really not that hard.
Old 12-11-2013, 07:59 PM
Accrdwgnguy's Avatar
My plan to fit 4th gen seats to a second gen was to bend/modify the 4th gen mounting tabs as needed and bolt directly to floor.
Old 12-12-2013, 10:30 AM
69 Ghost's Avatar
Cut the tabs in the back and reweld them on the other side the front location fits. The easiest way is to cut the tabs and bolt them in then bolt in the seats on the front and tack the tabs back on then take them out and weld them.
Quick Reply: 4th Gen seats in a 1st Gen Camaro
