LS1 Oil Pump pickup tube BOLT - who sells it?
Old 10-25-2013, 05:37 PM
swandude805's Avatar
Default LS1 Oil Pump pickup tube BOLT - who sells it?
Does anyone know where I can buy the correct bolt? most places dont sell them individually, its just included with the pickup tube. Thanks.
Old 10-25-2013, 05:54 PM
i r teh noobz's Avatar
I'm guessing its an M8x1.25 or M6x1.0. Take your new pump to a Fastenel or similar store and find something that works. There is nothing special about it other than the flanged head, and a washer will fix that.
Old 10-25-2013, 11:20 PM
1981TA's Avatar
Menards and Tractor Supply are good places to go too.
Old 10-28-2013, 11:21 AM
ROCNDAV's Avatar
Any Home depot, Lowe's, Osh or Tru Value would have those.
Old 10-28-2013, 01:08 PM
snook's Avatar
M6x1.25x20 mm. I would use a grade 8 or(10.9 metric equivalent) flanged bolt if possible.
Or one of these http://www.brphotrods.com/mm5/mercha...gory_Code=CNV6
I bought one because I don't like the 1 bolt holding it, it makes it easy to get the tube crooked or pinch the oring
Old 10-28-2013, 01:13 PM
ROCNDAV's Avatar
Originally Posted by snook
M8x1.25x20 mm. I would use a grade 8 or(10.9 metric equivalent) flanged bolt if possible.
I think that's a little big. I think it's an M6.
Yup, just looked in my parts book.
PN 11516398 M6x1x20 for 97-02 LS1
Old 10-28-2013, 01:40 PM
snook's Avatar
my bad, Ill change that. I have a parts book and was looking at the mounting bolts for the pump.
Old 11-04-2013, 04:09 PM
hey thanks guys, summit had one that i ordered and its on back order...im impatient though so i may go check out the parts store
Old 11-04-2013, 09:41 PM
KABRKA's Avatar
hey
have you tried BRP hotrods in Cumming GA they have a neat little oil pick up tube girdle. takes pick up tube from 1 x bolt to 2 bolt (very cleaver!!) i have a couple on the way just putting it out there!! cheers KABRKA
Old 11-04-2013, 10:43 PM
bczee's Avatar
I think Sook covered that already...
BC
Quick Reply: LS1 Oil Pump pickup tube BOLT - who sells it?
