Foxbody fuel system options and electrical.
Old 11-09-2013, 11:06 AM
ion05's Avatar
Default Foxbody fuel system options and electrical.
Ive been looking at the PSI fuel pump system kit.http://secure.ultracart.com/catalog/.../KIT-1007.html
It comes with everything i would need but for the $$$ would their be less expensive ways of making a similar kit? also on my swap i need ideas of how to get the ignition and starter hooked up to turn the engine with the key. I did remove all wires from my foxbody so i would have to run all new wires inclunding starter, headlights turn signal ect. any ideas or kits available?
Old 11-09-2013, 04:34 PM
gm-ntmr's Avatar
As far as the fuel system you didn't really give any power goals or motor combo so that will be a tough call?!
The wiring I would go get the factory mustang body wiring harness an use it. It will save you a lot of headaches trust me!
Old 11-09-2013, 05:00 PM
ion05's Avatar
running 5.3 with headers cam and 4.10 gears keeping it NA around 400 hp at the crank
Old 11-09-2013, 07:59 PM
gm-ntmr's Avatar
That fuel system should be fine I would just suggest to make sure you don't spend double money. Meaning if your goals down the road are to add some type of power adder that you will have to buy bigger pump and feed line to do it the first time.
Old 11-10-2013, 01:04 AM
ion05's Avatar
I do plan on going either turbo or supercharger down the road.
Old 11-10-2013, 09:51 AM
gm-ntmr's Avatar
In tank aeromotive stealth pumps
Out of tank I like the magnafuel 750
-10 feed
-8 return
Boost regulator
80lb inj safe to around 750 or so
Or 127 an go big
Quick Reply: Foxbody fuel system options and electrical.
