ls6 into 72 camaro coolant passage question
so I installed a 2002 ls6 into my 72 Camaro with an ls1 t56. my question is what do I do with the coolant passage fitting infront of the valley since iam deleting the throttle body passage which I know I don't need. I googled and have gotten mixed responses. Can I just simpy plug it or do I have to plumb it back into the radiator? thanks to all in advance.( I have not started motor yet)
It still needs to be routed into the cooling system. Either directly into the radiator, water pump or one of the return side Radiator or heater hoses.
You can buy Tee's for the Radiator or heater hoses. (jagsthatrun.com has many to chose from)
I usually try directly into the Radiator.
BC
BC
