Ls1 240sx swap, Coils/Injectors not getting power
Car: 96 240sx
Engine: 1999 Camaro SS
Tranny: t-56
PCM/harness: OEM
So i have completed my entire swap, and cant get fuel or spark while the engine is turning over.
Its a track car so i just am running a switch panel
switch for the starter
switch for the fuel pump
power to the (2) 12v PCM wire (orange)
power to the IGN PCM wire (pink)
Ground the (4) ground wires (black)
Flashed the PCM for Security theft (VATS), EGR and EVAP
Only codes i'm reading is ERG and EVAP sensors.
Otherwise everything else is plugged and should be working.
Crank, MAf, Mas, o2, etc all getting voltages.
Engine is also well grounded
The coils are not getting power on any wire, all four are readying grounds (some pulsing) while engine turning over.
Also the injectors are only getting a ground pulse signal, no power on the other wire.
Why is the PCM not sending power to the Coils/Injectors?
Did i forget to wire something up?
