I gotta stock LQ4 alternator question
Old 12-10-2013, 10:28 AM
Ksths2's Avatar
Default I gotta stock LQ4 alternator question
I heard the other day that i can't just run a big wire from the back of the terminal to the starter terminal like normal without running some sort of resistor or diode or something......? otherwise it burns up the alternator?
I thought these new alternators are all internally controlled?
Currently my setup is I'm using the stock PCM & wiring to the alternator and then using a Speedway 20 circuit fuse block/ wire going from alternator to starter then starter to fuse block and it works fine?
Old 12-10-2013, 11:02 AM
Pop N Wood's Avatar
if you have the ECM feeding the alternator than you are OK. it adds the needed resistance to the sense wire.
Old 12-10-2013, 02:28 PM
Ksths2's Avatar
Yes the original PCM is feeding the alternator, Thanks!
Quick Reply: I gotta stock LQ4 alternator question
