Long crank 6.0 & 4L60E - How I did it. *Pics*
I have a "long crank" 1999 6.0 engine and I had a 2001 4L60E trans that I wanted to use in my 67 Chevelle. I could not find any really good info other than ordering a custom torque converter. I started measuring and the 6.0 crank & 5.3 crank had the same ID for the TC - I then measured the ring gear to the rear block face and they were identical from the 5.3 to 6.0. The 5.3 has a dished flywheel and the 6.0 a flat fyywheel.
I held up the 5.3 TC to the 6.0 crank and flywheel and it would not mate up as the snout on the TC bottomed out. I guestimated the distance that it was from bolting to the flywheel was about .200"
I made 3 .250" spacers that I welded to the flywheel after elongating the holes slightly to match the 5.3 TC - then I drew up some spacers and CNC'd them to fit between the engine & trans to make up the .250" difference. This thing bolts together like stock. I am happy as I do not have to hunt down a unobtanium trans or TC - I am sure there are other ways but this worked great for me and didn't cost me much as I did it on my break at work.
Just thought i'd share and maybe someone can take something from this. Don't mind the grease, Will get torn down & detailed before install.
Spacers welded to 6.0 flywheel.
Flywheel & trans spacers. I made it two piece as I didn't need a huge chunk of steel the.
Engine, Trans & spacers.
The following users liked this post:
Homer_Simpson (04-05-2023)
Bellhousing is the same from SBC and BBC. Here is a link with dimensions http://www.theturboforums.com/thread...olt-Dimensions
I wonder if you will get a out of balance vibration.
Did you check the flex plate for any warpage after welding? Balancing won't help if it looks like a potato chip.....that's a little extreme, but you know what I mean.
Andy1
Andy1
I just finished it this past weekend. and I only used 1/3 of an inch spacers on the flywheel no welding no balancing this was a 2000 lq4 (long crank) to a 2004 60e... Edge Racing 4000 converter... It left no play at all between the converter and flywheel
By the way I used the 6.0/80e flywheel and just drilled a 60e converter pattern on the flywheel
I think it was only 99 and 00.
As far as I know all of them had iron heads as well, that makes them easy to identify in a wrecking yard.
Good post OP. I wondered if the same could be done with my 6.0 and t56, though I guess the starter might not extend far enough. I ended up getting another long crank 6.0 that needed a crank anyway and put a used short crank in it.
Nice work but the difference between cranks is .400". Since it's been over a year, I'm curious how this worked out for the OP.
As a side note: the 4.3 V6 4L60E transmission has the same input spacing as the long crank 6.0.
Yes t_raven, the 1999 and early 2000 iron head engines are the long crank engines. The newer aluminum head (2000+) 6.0 engines have a removable spacer and longer bolts installed between the crank and flexplate.
Hi question I'm going through the same thing
As a side note: the 4.3 V6 4L60E transmission has the same input spacing as the long crank 6.0.,
What year of transmission would I need to get I originally just used my 60e in my 01 Silverado
But I put the 99 lq4 in my truck an the transmission shot 30 mins after driving, the torque converter is stuck to the tranny an pump is bad, it was a new gm 4l60e I put in my truck 5xxx ago, any help would be appreciated it's my daily
