summit racing cast iron block?
Old 01-29-2014, 12:25 PM
kill4thril's Avatar
Default summit racing cast iron block?
has anyone used this block?
http://www.summitracing.com/parts/sum-150105/overview/
is it a good quality block? or do you guys have any suggestions for a block? looking to do a turbo build
Old 01-29-2014, 12:31 PM
4x4head's Avatar
Pretty sure those are just stock blocks (seasoned).
Old 01-29-2014, 02:27 PM
bczee's Avatar
Yeah.. just checked, cleaned, machine work done... could be either Gen IIi LQ4 or LQ9 blovks since they are bored to 4.030.
Old 01-29-2014, 03:32 PM
fox12303's Avatar
CarCraft just did an article in their current issue on this block. One thing of note was it did not come with all the main cap bolts. Otherwise it looks to be a good value. They are building a 427 stroker.
Old 01-29-2014, 06:54 PM
kill4thril's Avatar
ok thank you guys!
Jesse
Old 01-29-2014, 07:26 PM
redtan's Avatar
Kinda weird that they bore it out to 4.030 without any sort of pistons there. What happens if you get 4.030 pistons and one of the holes is too big for those?
Would be better to just get your own seasoned block and match it up perfectly to the exact pistons you're putting in vs. some shop doing a random bore on it.
Old 01-29-2014, 10:06 PM
chuckd71's Avatar
Does seasoned basically = used?
Old 01-30-2014, 01:58 PM
Turbine's Avatar
Yes .
Edit, what the heck, I know I've posted here before.
Old 02-07-2014, 07:00 AM
kill4thril's Avatar
Ok so I looked for that carcraft article and I cant fined anything about it and cant fined the magazine in any store. I was just wondering to make the 427 are they boaring the block to 4.125?
Old 02-07-2014, 04:00 PM
fox12303's Avatar
April 2014 CarCraft. Came in the mail last week so it should be on the rack. They overbored it to 4.060 with a 4.125 stroker kit from Scat to make 427ci. They have $7 grand in the long block with machine work and TFS top end kit.
GM catalog says the 6.0Ls are only good to .030 over?
Quick Reply: summit racing cast iron block?
