texas speed 1 7/8 swap headers for 1st gen camaros
Old 02-21-2014, 04:48 PM
billyflantos's Avatar
Default texas speed 1 7/8 swap headers for 1st gen camaros
Has anyone used their headers with their ls swap"d 1st gen camaros and if so what oil pan and motor mount and motor mount location did you use? Thanks billy
Old 03-02-2014, 06:29 PM
bdoobie69's Avatar
I am using them. Just slid the motor in this weekend. They are very nice for the price for stainless headers. I made my own motor mount adapters just using the stock location style. The only issue so far is that the one tube on the drivers side that runs over top the others contacts the rag joint on the steering. I am planning on switching that to a u-joint style connection. I modified my oil pan to clear the steering linkage. I think that if you were to use dirty dingo sliders you could slam the engine real close to the firewall and clear the rag joint and the steering linkage.
Old 03-02-2014, 07:57 PM
I have 1'' back motor mounts, do you think it would clear?
Old 03-03-2014, 06:32 AM
bdoobie69's Avatar
You may get it to work out. It might just clear fine. I attached a picture for reference. My rag joint was not seated down all the way to the power steering box so you may have more clearance than I did.
Attached Thumbnails texas speed 1 7/8 swap headers for 1st gen camaros-img_20140301_172635.jpg
Old 03-03-2014, 12:23 PM
thanks for the info and picture.
Old 03-07-2014, 07:34 AM
bdoobie69's Avatar
I will be moving the engine back 7/8" so I don't have to modify my driveshaft. I will let you know what it looks like with the rag joint clearance once I am done.
Old 03-07-2014, 12:57 PM
toxic99's Avatar
They look a lot like dynatech swap headers. Which I have on my car. With 1 inch set back plates they fit very well and clear the rag joint easily.
Old 03-08-2014, 07:14 PM
bdoobie69's Avatar
I just slid my engine back 7/8" and it will clear the rag joint. It is pretty close though. I would imagine that 1" setback would be totally fine.
Old 03-08-2014, 10:55 PM
thanks fellas..
Quick Reply: texas speed 1 7/8 swap headers for 1st gen camaros
