p/s line fitting#
Old 02-22-2014, 09:34 PM
kodyowenby10's Avatar
Default p/s line fitting#
I need the part numbers for the two fittings for a 05 5.3 p/s pump so I can get my own lines made to work on a cpp500 box. I have came up with 16mm o ring for return but no other specs on line size or tread etc. Im assuming the pressure side is the same fitting as well?
Quick Reply: p/s line fitting#
