Can anyone tell me what happened here?
Looks like a classic case of the driveshaft turning into a jump rope. This happens as a result of the driveshaft exceeding it's critical speed. Did this happen on a chassis dyne?
https://www.markwilliams.com/driveshafttech.aspx
Andrew
Andrew
Andrew
Andrew
It was a used driveshaft. If there were any dents, or folds, they were to small to notice.
I failed to mention, It ripped the tail housing off the trans. My mechanic thinks the driveshaft could've been a little to long. Also, I came across this right up-
http://www.turbobuick.com/forums/thr...y-pics.179024/
Mine was running 138 mph when it broke.
Won't hurt to check driveline and pinion angles and all that, but I highly suggest you google "driveshaft critical speed" and do some reading before buying a new driveshaft.
I had this happen and it took out a brand new built 4l60e with it. It busted the case and all.
Every short wide truck I have ever seen try to turn to redline on the dyno has also done the same thing.
It is an oversimplification to say "power has nothing to do with it". Just because something hit a resonant frequency doesn't mean it is going to blow up. Think guitar string. Hitting a resonant frequency does amplify the forces going through it making less capable of carrying all that energy, especially if other flaws or weak points are present.
At any rate pretty fing cool. Must have been something to see.
You can twist a driveshaft with 100hp if you spin it too fast. Like others have said, it's a critical speed issue, not power. Probably bad pinion angles too (did you lower the car?) because that can make it worse. Could also be too long as that would make things worse as well. But you're just spinning a stock shaft at too many RPMs, just that simple.
What Andrew said^^^^
Used shaft. Any evidence of rust, either on, or inside?
Talked w/ the shop I get my d/s from. They said that near 90% of the F body shafts they spin up, looking for vibration issues, show signs of deflection in the exact same location... The middle.
http://www.wallaceracing.com/driveshaftspeed.htm
