02 sensor wiring issue... I have no pink wires at my plugs?
I need some help/insight here guys. I am finishing up a harness and doing continuity tests on the wiring to make sure everything is hooked up properly. I have ran into a problem with the 02 sensor wiring. On the drivers side I have a green with white stripe,a solid green,a purple with white stripe,and a tan wire. Same wires on pass side but with a solid purple. I have no pink wires going to the 02 plugs. This is supposed to be a 2002 harness. It has triangle plugs for the 02 sensors which I
According to my schematics for a 2002, only the rear o2's have ignition hot pink wires. The front Bank 1 sensor 1 A-tan goes to a splice where the low reference wires are hooked together and also goes to C1-63, C1-25 C1-26, C1-28, and C1-29. It also hooks to A of sensor 2. The purple wires go to C1-65&66. The green wires are the heaters and go to C2-74&80.
