Fuel Filter Connection Question - Wix 33100
Old 03-26-2014, 03:44 PM
cwd240z's Avatar
Originally Posted by bczee
Suggest you check the fuel pressure at the Rail/Injectors. .but good to hear your up and running !
If it works, it Works !
BC
My pressure gauge on the rail was reading 60-62 psi at idle.
Old 03-31-2014, 02:46 PM
DOINSND's Avatar
I have a LS1 in a Sandrail. Ive been trying to get the Wix 33100 fuel filter to work because thats what I have been running. So I bought a new 33100 filter. Im using Russel Push on EFI fittings two 3/8 Russell #640850 and one 5/16 Russell #640860 to AN -6.
So I hooked up wrong fuel line to 5/16 it ran but fell on its face when throttled. So I checked fuel line pressure got 90 psi at rail then throttled and dropped under 50 psi. So I switched fuel line to 3/8 off pump it would not start no fuel. So I took filter back and switched it out thinking it was bad. Same thing no fuel of 3/8 side.
So I don't know if they changed. But I am switching to correct LS1 Filter Wix #33737
JUST DUNE IT!!!
Quick Reply: Fuel Filter Connection Question - Wix 33100
