G body fuel line routing?
Old 03-21-2014, 11:03 PM
6togo's Avatar
Default G body fuel line routing?
Getting ready to run the new -10/-8 braided lines on my GN that has a boxed frame and will probably keep the stock type tank setup and of course its will have a TT 427! Is it best to run them down the driver side together or split them up i plan to dual feed the rails? or dont it much matter?
The fuel filter does mount on the drivers side rail!
Old 03-22-2014, 04:03 PM
6togo's Avatar
Any G body guys out there?
Old 03-22-2014, 04:12 PM
llorracs93s10's Avatar
I am not much help since I do not have the same setup, but I have a returnless fuel rail off the driver side. I plan to route it behind the intake down the bellhousing on the passenger side and down the passenger side frame rail using the stock mounting points as much as possible. Mounting my fuel pressure regulator/filter on the heat shield off the original fuel line.
Old 03-22-2014, 06:57 PM
sprayed99's Avatar
fuel line routing doesn't really matter as long as it is free from obstructions and not near any heat producing items.
Now the way it feeds the rails and the position of the regulator does matter.
Old 03-23-2014, 09:43 AM
Old Geezer's Avatar
Lightbulb Maybe...
Try the G-body forum??
Old 03-23-2014, 04:05 PM
6togo's Avatar
Most of those guys aren't LS'd over there! I ended up doing both sides though!
Quick Reply: G body fuel line routing?
