How many amps should a LS starter draw while cranking?
I've got a 2ga battery wire from starter post to positive + side of battery and I put a 100amp circuit breaker in line to basically be the "fuse" in the main system and last night while firing up the car it tripped the breaker a couple of times if it had to crank for more than a second or two.
Is that way too low of a breaker? Do I even need a breaker inline?
thanks,
thanks,
