Blazer swap
Old 03-30-2014, 09:29 PM
LS1MCSS's Avatar
Default Blazer swap
I got started on my 85 Blazer swap today. It's getting an 04 5.3, 4L60E, and NP241 transfer case. Me and my son tore it apart in just over 5 hours but it will probably take me 2 weeks to put it back together. I have a lot of cleaning, painting, and wiring changes to work on. The motor/tranny/harness is ready to go in as soon as I get mount adapters. They will be here sometime this week. I still need to order my a/c relocation mounts.
Old 03-31-2014, 11:08 PM
the_merv's Avatar
Looks in pretty good shape..
Old 04-02-2014, 04:44 AM
LS1MCSS's Avatar
It is. I picked it up in Russellville and it has no rust. I did have to do some interior work. The carpet and seats were junk. I used seats and console from an 05 Silverado. My mount adapters came in yesterday so maybe this weekend I'll get the motor set back in it.
Old 04-02-2014, 10:56 PM
the_merv's Avatar
I wonder if you could use the dash from a never truck, make the gauges work alot easier.
Old 04-03-2014, 04:50 AM
LS1MCSS's Avatar
The gauges will work fine as it is. I'll cut and thread a factory temp sender so the gauge will work as it should. I already have the oil pressure sender on the motor.
Old 04-13-2014, 04:51 AM
LS1MCSS's Avatar
I got the motor and tranny stuck in yesterday. It looks like the 1" set back mounts may cause the tranny mount to miss alignment by about 1/2". That will be an easy fix. I really should get a new inner fender for the passenger side. Mine is bent from the previous owner having a wreck.
Old 04-13-2014, 07:31 AM
Checkmate's Avatar
Looks awesome.
Keeping ac?
Old 04-13-2014, 08:46 AM
LS1MCSS's Avatar
Yes, I have the brackets to move it to the upper passenger side. Also keeping the cruise.
Old 04-13-2014, 10:47 AM
the_merv's Avatar
Lot of room in there. What are you using for Headers..stock Manifolds?
Old 04-13-2014, 03:23 PM
LS1MCSS's Avatar
I will keep the stock manifolds if they clear the frame rails.
Old 04-13-2014, 03:40 PM
the_merv's Avatar
Not sure if the Blazer and a truck has the same frame, but on a truck it's not going to happen. The 2010-up Camaro Manifolds are really tight to the block and are the best bang for the buck in cases like this.
Old 04-13-2014, 05:54 PM
LS1MCSS's Avatar
I'll know tomorrow if they will clear.
Old 04-13-2014, 11:15 PM
mattcrp1's Avatar
I am doing a swap on a 76 swb truck. I found that the stock truck manifolds would not fit due to the flanges. I ended up getting trailblazer as manifolds for a steal. Maybe you can cut the flange and weld on v-band clamps?
Old 04-14-2014, 03:10 PM
LS1MCSS's Avatar
How much did the stock manifolds like clearing?
Old 04-14-2014, 06:08 PM
mattcrp1's Avatar
The stock manifolds hit on the frame by a good half inch. The trailblazer manifolds clear by at least a half inch in the tightest area. My main trouble spot was the passenger rear area.
Old 12-11-2016, 03:40 PM
1SlowFalcon's Avatar
Man I can't wait! Just got done pulling out th motor in my 63 and in search of a 5.3 to do this swap. What changes did u do to the rear end and driveshaft?
Quick Reply: Blazer swap
