Wtb parts to convert my 93 LX to 5 lug
You would be way better off looking on your local craigslist for these parts. SN-95 spindles, brakes and stuff work great for the low budget and are easy to come by. Keep in mind that they widen the track width by a bit though. Earlier cars widen less than later cars, not 100% sure on the years though.
Sean
Sean
Sean
Sean
Thanks for the info. Will try that
It all depends on what brakes you wish to run.
Just swaping the front rotor with new bearings will get the 5 lug swap done. This limits some wheel choices due to the bearing cap.
The 94-95 spindles will not change width but will need a spacer for the balljoint or change to 94-95 balljoint. With little mods you can fit the pbr and cobra brake systems. This again limits wheel choices.
You can do the brake lines a few ways as well. A simple adapter for the pass side for the factory lines or companies make braided lines with sn95 ends and fox threads.
I cant help with the 96 and up spindles.
