Any vendors that will make a "custom" harness?
Im looking for a unique harness. I just want all the connectors(excluding the ECM) pinned, with about 10ft of pig tail off each connector. I want it this way so that i can route everything just the way i want. Then i will trim to length myself, pin the ecm side, and make all the pink/orange/ground splices myself. So, do you know any vendors that would take a custom order like that? Thank you!
Custom harnesses
Current Performance and Speartech both make custom harnesses for LSx engine applications. I am sure one of the would make it for you.
Great idea, but im pretty sure there are like 30 companies making harnesses.
Thanks Bill! Yours was the first that came to mind! I will give you a call.
I have done a huge amount of research. I have also done a decent bit with LS harnesses. Here is where im at currently.
The only problem is that i havent found anywhere except eficonnection to get the connectors/terminals. Mouser has them but the problem with both companies is that they dont have the pins, seals, etc all listed with the connector body. So i have been having a tough time piecing it all together.
Thanks you!
Thanks for the names!
Thanks to everyone for the help so far!
I should add, the reason im doing this is that my harness, which i got from a guy who modifed it himself, hacked the poo out of it. It has no less than 50 non oem splices in it... All the connectors are good, but all the splices and non matching wire colors have got to go. I plan on putting some miles on this truck and want it good to go! I should also add that i have already had the truck (a 5.3 in my 90 subrurban) running for a couple years. Ran fine with this harness, but provided no "warm fuzzy feeling". Hence the rewire job.
http://www.eficonnection.com/eficonn...spx?ItemId=330
http://www.eficonnection.com/eficonn...spx?ItemId=376
http://www.eficonnection.com/eficonn...spx?ItemId=378
There is also
http://speedscenewiring.com/gm-connectors/
http://www.currentperformance.com/Co...s/LS1_LS6.html
and ebay also will have them with pigtails. If you decide not to use what you have, make me a deal and I'll buy it. I will build a spare harness with it.
