best buy on oil pan
best buy on oil pan
OK guys, the truck pan is 8.5 inches deep and the f-body or 5 or 5.5 inches deep i believe. I saw an oil pan on e-bay at a good price, i sent the guy an e-mail asking the guy about the dimensions He told me that it was an inch shorter than the truck pan ??? Where can I get the 5 or 5.5 inch deep oil pan at a good price??? Don't want to buy something that does not work for me.
Measure before you buy the H3/muscle car pan. It hangs low. I am not familiar with what "51 Chevy" you are putting a LS engine in. Truck? Probably any pan will work. car? I'd steer clear of the H3 pan!
https://ls1tech.com/forums/conversio...-oil-pans.html
First page is helpful...lots of used f body or ctsV pans out there on eBay from time to time.
You can get the entire f-body pan set up brand new from here. Be sure to look to the right and add the other stuff you need. All for under 300 bucks.
http://www.superchevyperformance.com...p/12628771.htm
T,
T,
Depending on how cheap you want to go, and how patient you are, maybe look for a 4th gen fbody in the boneyard. Look up any of the smaller LSx equiped suvs ( TBSS or its buick brother, v8 isuzu trooper, etc) and see if you can find one of those in the yard. Light trucks and vans should be relatively plentiful. If you can get to central indiana, there is a heavy truck boneyard in Spencer called "truck parts unlimited." It might be worth giving them a call.
NOOOOOOOOOOOOOO! That is the H3 pan!
I had my f body pan notched to clear my crossmember. You may need to do that as well. Can you put the engine in just to see or estimate what will work? Street & Performace notched my pan. You may want to check them out. They may have some advice.
T,
T,
